Den røde pluggen er anslutningen til instrumentbrettet, dette er en egen separat kabel som du kan få tak på. Men ta en orntli sjekk av selve sikringsplaten for du har hatt en orntli herdsmelte
Her er forklaringen på hvilken kabel som sitter på hvilken posisjon på selve kontakten med nr 1 oppe i øvre venstre hjørnet, sett fra baksiden på plata. (og for alle dere språk kompetente så ja dette er Google translate dokument som jeg funnet på nettet
B - Multiple connector (red) for panel wiring harness
B1 Terminal 61 (loading control) to terminal A16 of the Lima B
B2 Vorglühkontrolle of the terminal E10 cockpit B
B3 Fuel Gauge sensor from the tank to the cockpit via terminal E5 B
B4 Terminal 50 (starter) from the ignition terminal on B8 B
B5 unused B
B6 Connecting terminal 8 to relay 2nd place unused B
B7 Coolant temperature gauge from the heat sensor on terminal D29 to the cockpit B
B8 Terminal 50 (starter) from the ignition switch to terminal B4 B
B9 Terminal 53a (wiper) B
B10 Terminal X in front of relay from the ignition switch on the light switch to terminal 4 of relay 8th place B
B11 Terminal 30 (permanent) through the cigarette lighter fuse 3 and part of the glove compartment lighting B
B12 Terminal 30 (permanent) assurance about 3 for radio, cockpit (Clock) and the interior lights B
B13 Terminal 30 (permanent) unused unsecured / B
B14 Combination of K5 and terminal 3 of relay 3rd place unused (K5 -> coolant shortage) B
B15 Oil pressure 0.8 bar the oil pressure switch to the cockpit B
B16 Terminal 83a (Fog) switch from NSW B
B17 Connecting terminal 7 to relay 3rd place unused B
B18 Connection of terminal D3 and terminal 5 of relay 4th place unused B
B19 Terminal 1 (speed signal) from the coil to the cockpit B
B20 Terminal 83 (fog / light connection) from terminal 3 to No. 7 relay to switch NSW / NSL B
B21 Oil pressure 1.3 bar the oil pressure switch to the cockpit B
B22 Terminal 56a (high beam) switch from low beams stalk B
B23 Terminal 30 (permanent) unsecured to the light switch B
B24 Connection from terminal C11 unused B
B25 Terminal 71 Connection to the horn button B
B26 Terminal 58R (left parking light) from light or parking light switch) B
B27 Terminal 58L (left parking light) from light or parking light switch) B
B28 Terminal 30 (permanent) Fuse 4 on the hazard warning switch B
Releet er som Tur-Bo sier automatisk kjørelysrelee. Jeg har tatt for vane å alltid plukke vekk det slik at det ikke skal skape noen problemer.
Foreslår også at du tar deg en titt på din sigarettlighter. Jeg har nå hatt 2 biler der isolerplata mellom + kabel og selve høljet har smelta slik at det blir kortslutning/kontinuerlig overlast med resultat smelta kabler.
