1. The Vw power steering fluid reservoir is located on the drivers side inner fender well in the engine compartment right behind the head lamp.
2. Locate the oil cooler tubing in front of the radiator for Vw power steering fluid. Find the rubber hose that attaches to the tubing located near the drivers side lower corner of the radiator. Disconnect the hose and drain the Vw power steering fluid.
3. Flush the old Vw power steering fluid out of the Vw steering rack and pinion. Turn the steering wheel full lock side to side about 10 times. This sequence pushes the Vw power steering fluid out of the steering rack and into the fluid reservoir in order for it to drain out.
4. Some models have a sleeve type filter screen inserted in the fill hole of the Vw power steering fluid reservoir. If it has the filter, remove it and clean it. Clean out the sediment that also exists on the bottom of the Vw power steering fluid reservoir.
5. Reinstall the Vw power steering fluid hose removed in step (2) and fill the reservoir with G002000 Vw power steering fluid.
6. Start the engine and let the car run for 10 seconds at an idle. Important! Do not rev the engine up. Revving the engine could cause power steering pump damage.
7. Refill the Vw power steering fluid reservoir again with G002000 hydraulic steering fluid.
8. Start the engine and let the car run at an idle, turn the steering wheel full lock about 10 times from side to side.
9. Turn the engine off and top off the Vw power steering fluid in the reservoir.
Jeg tok ikke å løsnet slangen, men sugde ut av beholderen, snudde ratt frem og tilbake og sugde ut mer. Fylte opp med ny olje som beskrevet over.
