Sentrallås
riverh66
Car: T5, 2008
Sentrallås
Post by riverh66 »
Har nettopp byttet radio i bilen, også montert ryggekamera.
Bil stereoen er en 2 din. Tok ut den gamle, satte inn den nye. Plug and play. Kontaktene passet rett inn, allt ok.
Merket at fjernkontrollen ikke fungerer mere nå. Tok ut sikkring for spilleren, da funket fjernkontrollen igjen. Satte inn sikkringen og fjernkontrollen virker ikke. Sentrallåsen virker med nøkkel i dørlåsen.
John_Torvald
Re: Sentrallås
Post by John_Torvald »
Har du prøvd å reprogramere fjernkontrollen med radioen tilkopla? :
Programming remote portion of your VW Key FOB:
It is very simple but you must have 2 working keys for this procedure to work:
1) Insert master key in the ignition
2) Turn key to the accessory position without starting the vehicle
3) Insert second key(key you are programming) in driver’s door, manually lock the door
4) Press lock on the new remote
5) After one second, press lock again, which should beep to confirm programming complete.
*PLEASE NOTE*This method DOES NOT Always work - if your key does not work after trying this method, you will need to have a locksmith or someone with VCDs/VAGCOM program your key.
- See more at: http://deautokey.com/how-to-program-you ... qQ13e.dpuf
VW Transporter O.Caravelle 06 mod. T5.
riverh66
Car: T5, 2008
Re: Sentrallås
Post by riverh66 »
Takker :D skal prøve. Master key? har bare en nøkkel. Fikk beskjed at den andre var blitt borte....
John_Torvald
Re: Sentrallås
Du må ha 2 nøklar for at dette skal fungere desverre...
