00575-inntake manefoild pressure
17-10-controll differance inntermittent
caravelle 2.5tdi 97mod
noen som hvet hva dette er?
feilkode 00575
- Car: Multivan 2002 2,5 TDI
- Phone: 46426546
Re: feilkode 00575
00575 - Intake Manifold Pressure: Control Difference
Possible Symptoms
Reduced Power
Possible Causes
Solenoid Valve for Boost Pressure Control (N75) defective
Hoses incorrect connected, disconnected, blocked or leaking
In 1Z/AHU engines, stuck/rusted wastegate or actuator.
Possible Solutions
Check Solenoid Valve for Boost Pressure Control (N75)
Check Hoses
In 1Z/AHU engines, clean rust scale off wastegate/actuator to allow lever to move.
Special Notes
It is not uncommon for a TDI to set Implausible Signal Mass Air Flow Sensor (G70) faults and/or Boost Pressure, Intake Manifold Pressure faults when the engine performance is reduced due to excessive restrictions in the intake or exhaust systems. Restricted Catalytic Converters will directly affect turbocharger operation.
Possible Symptoms
Reduced Power
Possible Causes
Possible Solutions
Check Hoses
Special Notes
Re: feilkode 00575
Takker
Hvilken side finner du så grei oversikt over feilkoder?
Var slangen til styreenheten som var dårli
